Hi! I’m having a lot of trouble finding the correct settings to cut the canal plastic acrylic glitter sheets. Does anyone have find the correct settings? I have 160 speed on full, 3.0MM
Thank you so much!
Thank you so much!
Which glitter are you using I have used the medium proofgrade settings without issue on any of the ones I’ve gotten but one
but it’s a very different glitter pattern
We can’t discuss settings for non proofgrade materials anywhere but Beyond the Manual. I am moving this post over there. Also, I haven’t used this particular glitter acrylic, but others I have used were pretty close to Proofgrade settings for the cut.
It just purple glitter
I haven’t try in that setting, will try it and see if it works for me too!! Thank you!!
Here’s a good test routine.
I have used it. I set it on med blue acrylic. Cuts fine with that setting.
Thanks!!!
