I was cleaning my fan and took off the belt and when putting everything back together I cant get it tightened and now the little bolt piece on the far right where I would try to tighten with the little tool has fallen out and I cannot for the life of me figure out how to put it back in. it is not screwing in at all?
If I understand, the screw that mounts the wheel has been removed, the nut it screws into inside the gantry arm isn’t captive and has been displaced. You could try to drag it back where you can see it with a magnet, or fish it back with a piece of wire through the slot.
You will need a mirror on the bed so you can see up under the gantry. - and a lot of patience.
