Cardboard Etching
Okay, now I’m confused. @Tom_A said you need 2 postings for non-PG projects where you share settings. The first is in Made on a Glowforge but without the settings. The second would be in Beyond the Manual with settings.
You said essentially the same thing except included PG projects with non-default settings needing to go into Beyond the Manual.
Let me see if this is correct:
  1. If it’s made on a Glowforge and it doesn’t mention settings it can go in the Made on a Glowforge category. Materials don’t matter if settings aren’t mentioned.
  2. If it’s made on a Glowforge and it’s PG materials and any settings mentioned are default PG settings (there are 5 right - 1 cut, 2 score and 2 engrave defaults correct?) then it can go in Made on a Glowforge.
  3. If it mentions using non-default settings for PG material it has to go in Beyond the Manual.
  4. Since there are no default settings for non-PG materials, any mention of settings for those projects must go in Beyond the Manual.
  5. If you mention non-default settings that mention must be removed to post in Made on a Glowforge or moved to Beyond the Manual regardless of material.
Is that right?
