I bought the feather earrings from the catalog for unlimited prints. When I try to pull them up now a different image I had loaded after them comes up instead of the feathers. I have reset the design and it still shows the second image. I have closed my browser, reset my cache, and deleted all my cookies, and reset the design again and I still can’t grt the feathers to come up. Hope I can get this fixed. Thanks!
I had this happen too, and finally managed to fix it. Now if only I could remember HOW… I think it was by deleting the incorrect images out of the design so it was empty, and then resetting. It’s worth a try!
I’ve posted about this before, as well. If what @geek2nurse says works that would be really great, so try that, but otherwise, staff had to manually go in and add a whole new iteration of it within my “library”. This is all do to the “auto-save” feature that was implemented a few months ago, and I did as you did, but to no avail.
Hopefully the above advice helps, if not, then support will update you within the next day or two
Thanks I’ll try it!
Thanks so much! At least I know it’s fixable!
Not sure what I did but I somehow got it to work! Thanks for all the tips!
Thanks for the help. I’m going to close this thread - if the problem reoccurs, go ahead and post a new topic. Thanks for letting us know about this!
