Be careful…
The magnet of the Removal tool stayed attached to the lens and removed itself from the tool!
Seems I almost left part of the Removal tool attached to the Lens when I cleaned it…
Luckily I “always check for all your tools before closing the patient!”
Seems a fairly common problem. That magnetic ring is fragile. Ours cracked and came loose from the tool, remaining stuck to the lens. Took me twenty minutes to figure out why our Glowforge wouldn’t run.
I think my ring came off the third or fourth time I cleaned the lens. It was a bit of a surprise but fortunately I noticed it before I reinstalled the lens.
I’m debating whether to epoxy the bits back on or just make my own from magnets embedded in a plywood disc mounted on a stick. I’m not thrilled about spending $15 plus shipping for another one with the same design issues.
The bits went back together pretty easily but I’m worried about specks of magnet dust sticking to the lens housing or inside the head, hence the idea of potting the whole thing in epoxy… But I’m leaning towards wedging a few of the little magnets I have on hand into a bit of plywood. Less sticky goop to worry about.
Mine looked exactly the same. I have been so usy with the twins recently though that I have not had time to do anything about it. These should be replaced by GF at no cost.
You should post that picture in a new post here to generate a support ticket. I’m sure support will credit the cost and replace it for you.
The magnets are brittle, but the number of broken lens tools we have seen here represent a tiny fraction of delivered units. Shipping damage happens.
