Could probably be done in less but, I’ve got low-and-slow settings figured out for that stock that shows almost no burn-through (Hammermill 100lb cover, .028” thick, 200 / 13 1 pass, if you are curious).
Thanks for sharing cause I’m waiting on my pro and I do most of my work in pearlescent metallic card stock and i’ve been looking for help in settings on card stock so that I wouldn’t get any char with the settings at all so that when I start working on my pro I have some settings to start with. Again thanks for posting
That’s for a very plain cover stock. I use pearlescent metallic stuff for some of my pop up cards. I have cut a few cards from CorendonS Stardream 105lb cover using slightly more power – .035” thick 200 / 17 1 pass. I am using slightly less than half power for scoring on both stocks.
A small single object with some narrow parts seems to work well for testing settings. I am using a little spiral but, a star would work nicely, too. I try something, move it a little down the test sheet, try again, etc. I have been going for “low and slow.” It’s possible there are good settings at the “high and fast” end, too. I’m just getting started playing with it.
Anyway, I hope that helps and, I hope you get your Pro soon!
