While it will end up in other projects eventually, I wanted to do something more fun with the Celtic keypattern design than a test sheet. So, I turned it into a bookmark.
The spirals did require a second round of adaptation. The breaks I added to the long tails forming the outer circles was originally too narrow and, burnt away completely. More a function of the angles and direction of the cuts, though I think. There are other bits of the designs that are narrower strips of paper.
I haven’t played with trying to control the direction of cuts, yet. A lot of the CNC craft machines cut based (partly) on vector node order. I’m not sure if the Glowforge does or not. It should be less relevant because the laser does not use physical pressure like a knife blade but, it might be useful to reduce the dwell time on a specific spot like that.
