I made my first $ with my Forge today, but it took way longer than it should’ve because I run every proofgrade cut twice, always, because it hardly ever ever cuts through the first try. (Yes The machine is level, my humidity levels are very low, and this happens whether the wood is warped or flat)
All I want to do is tweak the settings they’ve set for proofgrade by a smidgen, but when I choose “manual” instead of proofgrade, it doesn’t show me what the proofgrade settings would have been. It sets speed to max and power to min, so I have no idea what to set things at to just go a little slower or a little more powerful than the PG settings.
How can I see what settings it WOULD have used if left on PG?
So, what you have described is exactly what I am doing, but it sets the settings back to max speed min power when I switch to manual after proofgrade. I’ll try again tomorrow to make sure I am not going bonkers here…
Sometimes I have to click out of the settings box (effectively closing the settings menu) and then click back into it and change to manual to see the settings. Like it takes a second, or an action, for it to populate.
@JimSocks Thanks for letting us know about this. I’d like to make sure you can cut through Proofgrade materials reliably using the Proofgrade settings.
Once you’ve inspected and cleaned, please try another print. We included an extra piece of Proofgrade Draftboard with your materials shipment for troubleshooting. Please print the Gift of Good Measure on that Proofgrade Draftboard and let me know the result. If it doesn’t print well, please let me know the date and time of your print and send photos of the front and back of the print.
It’s been a little while since I’ve heard back from you. I hope that’s because everything worked out! If not, just let me know and we’ll get it solved.
I’ve extracted the logs for your print and I see you’ve been printing on Proofgrade Walnut Plywood. Have you experienced the cut through issues on other materials? If not, please print the Gift of Good Measure on Proofgrade Draftboard using the Proofgrade settings and let me know the result.
