The lens is inserted in the proper direction. It should snap into place, and it moves up and down in the printhead to focus on various thicknesses of material.
Draftboard is a known commodity specifically manufactured for Glowforge use. It is important to use this for diagnosing problems because it rules out material being a contributory factor.
The fan does not look too terrible actually but the bottom of the carriage looks awful. If you flick the fan and it spins up and does not stop suddenly it should be ok. This is what mine looked like at the worst…
I appreciate that but it’s not a small price ticket item and when you rely on it solely for your business there should be the service to match it.
Happy medium would be good. Hopefully there is an answer tomorrow.
There is something wrong with your belts or there is a physical collision happening to throw it off course. Is the material extending over the edge of the honeycomb tray?
You can see on the first circle that it hit something that kept it from moving to the left. After that, the cutting point is not where the computer thinks it is. Find out where it hit (it would be above where the circle went straight) and change that situation. As it is only once and at the extreme left of where the head actually went tells me it is an obstruction there and probably in the gantry.
