Vinyl and paper is the best use for it. I’m still not sure how efficient the Glowforge will be for cutting paper. Other than paper, I use the Cameo to cut vinyl for signs and decals; Paper stickers for printed party favors and labels; Heat Transfer Vinyl to make shirts, Can Koozies, etc. The only thing listed that you can’t cut at all is vinyl (due to the PVC fumes). However, the Cameo does a pretty good job of “kiss” cutting materials - cutting through only one layer of the material to leave a backing that holds the design together. I’m not sure if I we will be able to set up the speed/power of the Glowforge to attempt that. Here is a link to some of the stuff that I’ve posted before.
