Hello, i tried “inlays” with acrylic with “krazy fix with UV light” regular clear glue but i can’t find a glue that dries clearly, i always see where the glue was applied, any suggestions? Tips, recommendation?
Thanks.
“weld on” adhesive. It’s a solvent that basically joins faces to each other…
I use Weld On like @eflyguy mentioned. Works good but be careful it doesn’t ‘spill’ across your work as you will be able to see it.
It takes a touch, it’s thin and runny. I use a syringe and carefully apply the solvent at the joint and you can see capillary action carry it in across the joint.
This might help with careful application…
Weld-on comes in gel, not only liquid. Works just as well.
This may be of interest.
