Is there any other place to get the Compact Filter Cartridge… I need one badly however they are currently out of stock…
I’m sorry the part you want is out of stock! I think I have a more immediate solution for you: the Glowforge Air Filter cartridge will also work in the Compact Filter.
When we designed the improved Glowforge Air Filter, we tried to make the new cartridges compatible with the older Compact Filter design too. We completed testing and they work perfectly together. The Glowforge Air Filter cartridge lasts about 20% longer, regardless of which air filter you use. You can purchase it in the Glowforge shop, and it is currently in stock.
