I just did a bit more research on the cork fabric from thethackery.com.
Their products are also available through Amazon.com.
The cork fabric comes in a variety of colors.
The fabric is made of 50% polyurethane, 35% cotton, and 15% polyester. I did a quick web search on polyurethane and polyester and read that both are laser safe. (Might anyone have contradictory information?)
Thethackery.com suggests cleaning the material with a damp cloth and gentle cleanser. I marked up a piece of the fabric with pencil then washed it with a sponge and hand soap. It cleaned up nicely.
using settings for Medium Proofgrade Leather, it did not catch on fire, and I did not see any flareups
I am using a Pre-Release Unit, and think folks should test the fabric with lower settings in a Production Unit
Lighter test
cork starts on fire before fabric
fabric did not melt
no strong chemical smell detected
Water test
it floats (small scraps)
after about 60 minutes soaking (submerged in water), I cannot peel the cork layer off the fabric
Tear test
I can tear very thin pieces of the fabric by hand
I cannot tear thick pieces by hand
I scratched a piece of fabric up with a mechanical pencil, it pulled up little bits in a few areas, but I could rub them down with my thumb and they disappeared
I can poke through the material easily with a needle or pencil tip, but the cork (I guess due to elasticity) seemed to meld back together (I cannot see the holes)
If anyone else tries cork fabric, it would be great if you could share what you learned.
Polyurethane has some mixed info. Basically all plant and animal based stuff produces some cyanide when you burn it, but polyurethane produces it in much more copious quantities due to the availability of elements in the right proportion.
It is apparently is fairly reactive so won’t stay cyanide for very long once dissipated into the environment. If I understood it correctly. Maybe the amount you vaporizes to cut isn’t that much?
Also apparently it can get messy, melty and sticky in your machine.
I didn’t notice anything melty in the machine. And, when I tried to light the fabric on fire with a lighter, it didn’t melt. Maybe the percentages of cotton, polyurethane, and polyester deaden the negatives of laser cutting 100% polyurethane?
I don’t usually respond to posts and I’m quite happy to lurk (for years it seems), but I thought I would mention that your links to Thackery are incorrect. Thackery.com points to a SmartName advertisement domain that gets rewarded for people clicking on search links. The domain I believe you intended to link is www.thethackery.com and for convenience here is the direct link for cork fabric specifically:https://www.thethackery.com/default/tailoring-sewing/cork-fabric.html
Thank you for introducing me to this wonderful material.
