So I’m experimenting with an inlaid corner design for a sort of frame. The result isn’t 100% there yet, I think I want to work on the kerf adjustment a bit, but overall I think it looks pretty cool.
The intent is to use exotic woods, but as a test I painted some Baltic for contrast.
I think either would be beautiful, but I’m really digging the gold. It really fits with the art nouveau thing youve got going on.
Annoying side question, what gold paint did you use? Is it acrylic? I’ve messed around with gold ink and gold watercolor (just what I had on hand), but neither worked very well. Predictably, I suppose.
Love the idea of shaped corner connectors for frames…those are stunning. (And I’d love to see them in exotics, but I’m more of a “natural woods” as opposed to painted kind of person. The gold does look pretty sharp.)
Aesthetics at this size. Entire thing will be glued to a backing layer. Hard to see scale exactly but the sides are an inch wide, so the floral pieces are pretty small.
Well, dang. I will say that Reaper is very quick to respond, but unfortunately this was their response:
Thanks for asking.
Sample paint is just that, a sample. It is not part of our regular line and has no number. They are often experiment or mistake colors we chose to share instead of throw away.
OMG that’s hilarious !
They send you a sample, but it might never be identified !
That matches my ‘best find’ today when shopping. I bought some ‘Wonky Grapes’, I kid you not.
Over here, some of the supermarkets have been making great thing of selling mis-shapen vegetables as ‘wonky’, like carrots, etc. , but grapes ?
OK, they’re smaller than usual, so out of their spec, but sweet and juicy so far.
Well, that was the intent, I thought the leaves would “bite” a bit more, but the little chevron V piece actually locks everything together pretty well.
That being said, this isn’t intended to be structural, so it’s not my primary concern. An idea for the next design perhaps.
I’m doing something similar with a narrow ‘rim’ for the front of a deep, box frame.
I’m using a double dovetail insert - imagine a butterfly, locking the two flat sections together, set in the corners.
If that is what I’m thinking of, it’s known as a bowtie spline and is commonly used to help prevent large splits from getting larger (often being used as part of the “design” of the piece).
Enjoyed the video. Sneaky use of the curved end of his belt sander to sand the sides of his splines !
I assume that’s how he came up with his ‘style’ !
Is that similar to what you were describing? It seemed similar to me, but I could have been reading more into it than was there.
I’m hoping to use this technique to make other shapes that can hold picture frame corners together in a decorative fashion, and just use a different shape than a bow tie.
Yes that was exactly it.
Given a little time, I’ll sort out a drawing of what I’m doing - a box frame for my small fans.
The actual frame is in its third iteration at the moment, and I just need to sort out a ‘stand off’ part that will lock into the back, and I’m good to go.
Loving the idea that I can use the GF to not only make the whole fan, but also the frame and the assembly jigs as well.
