I was looking at this post and was wondering how exactly I would be able to apply this method to a M3 x 0.5mm screw such as this one here: McMaster-Carr to 1/8 in thick acrylic. Any help would be appreciated, thank you!
Adjust the size of the engrave and center cut, and change the engrave power settings to suit the depth required for the screw you are using.
In both cases I would both thread the material, and make the countersink with either hand tools or small Dremel like device. The Glowforge will do it but it may not be the best tool to do it.
