Creating a Template for Repeat Projects
Yes, don’t*.
Use cardboard or something else that is so inexpensive that you don’t care. You’ll get better alignment if the jig and the artwork are in the same file. Basically you load cardboard, cut your jig out, place the cork, turn off the jig cut lines in the UI and turn on the engrave. Boom, perfect. (Just make sure you have your heights set properly, cardboard is probably thinner than your cork.)
* Unless you have snapmarks, then maybe.
