I am trying to may a key cutout for a Realtor. I have the logo that I am trying to cut out and glue on top of the key that I have made. I can’t get the glowforge app to create cut lines for the insides of the “bow tie” part of the logo.
I also tried to take the PNG logo file into Inkscape and convert to path but I can’t get it to do that either. Any tips or tricks to get this to cute out the lines? I have attached screenshot of current work as well as the PNG logo file for anyone who has any ideas!
Nope. That’s a monstrosity. Look at all the weirdness. So I undo that and think to myself “I’ll manually remove the extra nodes.” It’s painful but the easiest thing here.
Nope. I quickly realized that the problems are deeper than just too many nodes, there’s all kinds of inaccuracy. There are lots of problems, but look at this corner, for example. In the next picture look closely at the upper left corner and you can see it’s not a vertical line, it’s peeled away to the right:
“Big deal, that’s not bad”… and that may be true, depends on what you’re doing. If you plan to ever use this to do anything high precision like inlay or something large scale like a wall sign, it’ll become a problem.
So… the only solution was to manually redraw the entire thing by simply using the pen tool and drawing it carefully. This process is tedious so I won’t bother to document it, I’ll just post the final result:
Anyway, you didn’t ask, and the traced version may have been perfect for your needs… but if you want a truly perfect and clean SVG, here you go. I did this largely as an exercise to keep my skills sharp, you know?
