I picked up a crumb tray that must have not been cleaned in three years
it was so filthy, i was scraping away chunks of crud off it!! EHWWWWWW
Anyway after 6 washes, power washes, soaking in bleach, ammonia (not at the same time)
single green, fabulosa, dawn, I have given up on it, and decided it was time for the fire cleanse
There has been discussions on putting a tray (just the steel part, folks)
into an oven, and concern that food / laser wood gunk may cross contaminate
so I loaded up the BBQ and trying that - Its in progress, I expect it will take 4-6 hrs
to see any results
I have thought of just laser engraving an entire empty crumb tray, but as bad as it is I am not very bothered by it. I have had three machines but only one crumb tray. If I get bothered enough there is always …
Pricey though it is.
Did you try sandblasting it? It would make it brighter
If you were cooking things that would fall between the barbeque grill they would not do so on the metal part of the crumb tray. At that point if it was at all warped, it would not matter.
burning got the center area clean, but not the surrounding, so I am onto something, I was able to extend the area using a power washer (nozzle 1/4" inch away from the tray) but its still a long prossess to go…
