Custom Scrabble® Tile generator
Sorry, I didn’t describe the workflow. What I do is this:
  • tape the material down at the corners so I don’t disturb it when I flip the engraved piece
  • ignore all steps except one of the engraves (either the letters side or the back side) and the outside cut border (the green rectangle)
  • order the steps so the cut is last
  • do the first engrave followed by the outline cut
  • use a piece of tape to pick up the cut-out rectangle
  • flip the rectangle over (using the remainder of the material as a jig to hold the rectangle in the right place)
  • now ignore the steps you just did (the first engrave and cut), and un-ignore the second engrave and cut (the blue lines).
  • do the second engrave followed by the cut that separates the tiles
  • remove lots of paper from the many tiles. Gorilla Tape® is your friend here.
