I’ve created a couple of geometric shapes in Illustrator, exported them to SVG and opened them in GFUI to cut them. All the shapes have the correct size in GFUI (I placed them next to the ruler to ensure they have the correct dimension). When I cut them out and measure them afterwards they are approximately 1cm too long in every direction. I’ve wasted 2 sheets of acrylic today and I have no idea what could be the cause for this behavior.
Did anyone had this issue before?
If you prefer to work in metric, you will want to create your artboard in Illustrator to 508 mm x 304.8 mm (which corresponds to the size of the bed on the Glowforge) and design your shapes on those.
It’s actually better if you use Save As to save the SVG instead of exporting it, but if you do export it, make sure that Preserve Illustrator Editing Capabilities and Responsive are not checked.
Examples of the correct way to save an SVG for the Glowforge interface are discussed here:
You might want to test it on some cardboard before shifting to another sheet of acrylic. (Not sure if this is the problem, but it’s a possibility. Files that come over from Illustrator are generally not resized if the SVG is saved correctly.)
Thank you for the suggestions. I’ve created a new document with another simple shape and saved the document as SVG instead of exporting it. The result is the same. In GFUI the dimensions are correct, but the result (this time cardboard) is wrong again. This is really strange and totally surprising to me.
I’ll try to recreate the shape with Inkscape just to have another reference point and see how that will turn out.
I cant help with your issue, but you have found out why I do anything new in cardboard first as a test. Nothing more frustrating then wasting sheets of acrylic due to technology fighting back.
That does sound weird. Screenshots might help Support to better see what’s happening. After the piece is cut, before removing it from the Glowforge, take a screenshot that includes both the artwork and the image of the cutout piece, and make sure to include the rulers for reference.
Hey, thanks for all the suggestions to solve the problem. The issue was clearly on my side! I’ve used a big quilting/sewing ruler with a lot of lines and numbers on it. Unfortunately, I’ve used the wrong baseline that is 1cm off from the 0 baseline on that ruler. I was re-checking the measurements of my shapes again with a different (simpler) ruler and everything looks fine now. Stupid 1cm off baseline!
I’m glad you resolved it! I’m going to close this thread. If you run into any other trouble, please start a new topic, or email us at support@glowforge.com. We’re here to help!
