is there any way I can cut outside with this kind of file.? (no engrave inside just cut outline) or do I have to make another outline file? if this is a case, can you pls derect me to how to make a outline on inkscape? I just started everything 2 days ago.
The easiest thing to do is to get a vector version (SVG, etc) of that image instead of using the raster image (png/jpeg).
If you are very attached to that particular image you can trace it in your favorite vector program (inkscape, ai etc). I would search the forum for “trace bitmap” in that case.
Wikipedia has a bunch of SVG world maps. I would start there.
in inkscape, highlight the image, then look for trace bitmap in the path menu. it will open a dialog box,lots of options but just click “OK” it shoudl make a path out of the trace. Then you can adjust the fill to none and stroke for that path to solid black to get this…
hi thank you for response. I did this before but I realize if you do this there is two outside line like there is 2 path for out side of black line and inside black line so i needed trace my self which i took whole day for super easy image. can you make only one path for trace??
