I frequently cut wood to stack and glue together (to make holders for various things) and despite the actual cut files being exactly the same, many times when I stack the items, there will be inconsistencies so that they don’t line up perfectly.
Usually it’s very minor, but there are definitely times where it’s just way off.
I always ensure the wood itself is perfectly flat on the bed.
Is there some way to get perfectly consistent cuts every time across the entire cutting area? Meaning, if I cut the shape out at the top left of the cutting area, I expect the same cut to be exactly the same in the bottom right.
