Cutting board alignment/centering
As @beerfaced said, use the “set focus” button and click on your cutting board, let it re-scale the camera image accordingly, THEN place your artwork. If you place your artwork before doing that, you’re lining it up with a photo that isn’t scaled to true size, and things will not print where they appeared on screen.
Longer explanation here if you’d like:
