Cutting out images
There is a design in the free design section that is a template with all of the shapes you will need. You can add it to your library and use it whenever you need a shape. Here is the link to it: Cut Shapes Template
There is a second version later on in the post. Right click the file and save to your computer as an svg, then upload into your library.
