Welcome!
There is a fair amount of variability in fabrics. You are really best off doing some tests with the fabric you are using. This is a popular method (though you might want to enlarge a little for fabric):
Don’t know what settings to use on a material? The only way to be sure is to test. Good news! You can effectively test on a thin strip on the edge of your material, it’s fast and easy.
I use this shape to do so (SVG attached):
[Material_test]
Click here to download/save
Or click here for the ZIP: Material_test.zip (3.3 KB)
To use:
Set the first operation to score (the numbers). You’ll use these to identify your cut pieces later.
Set each of the curve shapes to a power/speed combo t…
Maybe start somewhere around 500 / 60.
Searching in the Beyond the Manual section (the only section where custom settings are allowed) for “cotton fabric settings” will also turn up other people’s settings.
