Da Vinci Glider SVG Files
SVG Files are included for the glider posted here.
Minor modifications from the one posted here to make sure the wing “sandwich” are aligned.
The round edge on the lower wing piece has been shaved so the wing assembly can be inverted on the body.
. I feel like these design changes make the wings look cleaner compared to the original design below.
Da Vinci Flying Machine FSL Project _0005_Layer 145
Da Vinci Glider Body-2
Da Vinci Glider Fabric-3
Da Vinci Glider Wings-1
The yoke holding the wings in place doesn’t fit exactly and had to sand two of the tabs off.
For the fabric, as it is almost an exact cut, I aligned it on the big wing and put a heavy book on one half. This allowed me to stick the other half without messing the alignment. Then flipped and repeated the process.
Additional details here.
Adding a pic of the back side of the wing to show the sandwiched fabric.
Great share! (That’s Catalog material.) :grinning:
Fabulous! Now I want to have a reason to make one :stuck_out_tongue:
Thank you so much!
Thanks for the share!
Thank you so much for your generous share!
Very cool! Thanks for the share!
+1 to the todo list!
Wow, that’s gorgeous! Thank you so much for sharing with us.
Did not realize I needed one of these until now. I am going to print this for the challenge of putting it together. Thank you!!!
Thanks for sharing this. It’s a very cool design.
Very nice design! Thank you. I will have to try this out just for decoration to hang above the laser.
Thank You! I will have to make one to hang in my workshop.
