My machine stopped cutting halfway through a job.
After reboots and several tests with different files, settings and materials, the tube is simply not firing.
Is there a simple test to figure out exactly whether it’s the tube, one of the power supply or something…?
I already sent one back after only a month and it took three months to get it back… trying to avoid that again
Generally, the tube will decay slowly over time (I am having to reduce speed by about 25% now) whereas a power supply issue will cause a sudden failure.
So it’s likely the latter, but it makes little difference because either way, your machine will need to be replaced.
