Excellent work! And now I have that song from SNL going through my head, too.
Cut a hole in the box β¦
The engravings are incredible!
Do you have any advice on converting an image for engraving? This is beautiful work!
I found what I needed in Tips and Tricks and the Help Center (links for the curious).
While they give instructions, I have a long way to go before I can recreate this work. Cheers again!
This is amazing! Do you have a link to the file as may step son would love this!
You are better off making your own file, for the material you have. The tolerances will vary.
Use a site like Boxes.py and create a box inside of a box smaller than the thickness of your material to nest it inside.
@bwente is correct. The material thickness will vary slightly and make the box too loose or too tight. I used this one to make the boxes:
The key thing to remember when using this box designer is setting the box to inner or outer measurements to make sure one fits inside the other.
