Default setting suggestion
Your comment says “thick basswood hardwood”, while your screenshot shows “thick basswood plywood”. Plywood and hardwood are not synonyms.
I checked a chart of PG settings someone put together last year, and they are the same as the settings you see now. They have not changed.
Here’s a post from 2018 also confirming that the speed for medium basswood hardwood was 200 then as well, so that hasn’t changed in at least 3 years.
Since you keep mixing them up, it seems like perhaps you’re accidentally choosing hardwood when you mean to choose plywood, or vice versa. As the hardwood and plywood don’t cut at the same speeds, this will cause you problems with your projects. Make sure you select the material you’re using.
