Deleted an object from free with premium file, can't get it back
I downloaded the marble chase desing and accidentally deleted one of its wheels. I tried undo but it didn’t work. How can I reload the desing fress with everything complete. When I go to cata;log it just open up the current version with the missing wheel.
With the design in the GFUI click on the three dot at the top, Design Details and then reset design in the window that comes on the right, see if that works…
If that don’t work then support can reset it for you …
When you edit a design on your Workspace, the changes are automatically saved as you make them. That means that if you close your browser, navigate to another page, or just hit refresh, your work will pick up right where you left off.
Should you make a change by mistake, you can use undo any time until you leave or refresh the page. If you want a clean start, you can always go to your dashboard and click the upload button to upload the file again. If you got the design from the catalog, then you can start fresh by opening the design, clicking on the three-dot icon, then Design Details, and choosing “Reset Design” to remove all changes.
