Hello! I have an .svg file with a complicated run of etching. The file will render into the GFUI, but the section to be etched appears “blobby” and low-resolution. And if I run the job, it etches as it appears on the screen, not in the file (I.e. low rez).
If I change the etch to cuts, the image appears correctly on the screen. If I change it back to etching, the image loses resolution again.
I’ve tried breaking the etching into many small parts. No luck. Any ideas?
Here’s a pic of the design as it appears in Illustrator:
