Please help! Inkscape 0.91
Coming in smaller than design.
But it seems to be random as to when.
Search the forums, you’ll find several posts on how to setup Inkscape (hint: 96dpi seems to be the key)
I did and came up empty. I’ll try searching for 96dpi. Thanks!
Edit… found this, thanks!
OK so here’s the crazy thing. I changed my settings to be all 96 DPI as per the other post. If I do that and just save as the other file it doesn’t work. But if I start a new ink scape file and copy and Paste the geometry from the other one in it works.
Just upgrade to the latest version of Inkscape. (0.92.1 something or other.)
It doesn’t have that problem anymore.
I’m glad you resolved it! I’m going to close this thread - if you run into anything else, go ahead and post a new topic.
