So I am completely useless at screwing anything into a wall straight or in the right place. Every shelf is slightly wonky and every picture needs blu-tak to balance it. So I thought I would design some ways to hang things.
These are particularly designed for gluing onto the back of acrylic sheets and give a stand out from the wall at the same time. They would work with anything hidden though I think.
The core idea is that bits screwed to the wall push or hold up a fixed part of the frame.
By either rotating or sliding it should be possible to adjust up/down or side/side until things are square.
Some of these must be fitted exactly on the frame, some can be a bit more casual.
I mostly had in mind a single hanging point in the frame, but you can use some of them in pairs top left and right.
Hope this helps and if anyone has any other variations I would love to see them.
Incidentally, I went looking on Amazon for anything that might help and couldn’t really find anything.
EDIT: Colour scheme on the “Dead Square” example is wrong. The olive bit should be a normal plate with a whole in the middle - it is correct in the SVG.
While no doubt my husband will get your diagrams immediately, I will have to study them at length to figure out what is going on… I am sure this will come in handy at some time though, so I thank you for sharing!
just looked again and still don’t actually see the red spot but I right clicked in that area a couple of times and it finally showed “save image as” so its there but it must be really tiny in my browser.
Don’t mean to make more work for you! It appears there are others as mystified as me though, so if you can find the time to illustrate, it will be much appreciated.
FYI, if you want to make the SVG easier to click on, you can edit that post and increase the size in the tag. The Discourse forum software has a weird behavior where it reads your SVG and if, for example, the file is 3x5 inches, it thinks it’s 3x5 pixels. I usually just add a couple of zeroes to each number and it comes out to a reasonable size.
Alternatively, you can upload a ZIP file and not worry about it.
You guys!!! Next time you are hanging something…lets say a picture frame. Take some painters tape, put it across the back of the frame and mark the holders with a pen. Peel off the tape and put it on the wall. Check to make sure it’s level. Drill holes or hammer nails into the marked spots. Remove tape. Hang level picture. This literally works for everything. I hung blinds with this technique last weekend. Hope this helps you all!
This works if the hangers are symmetrical. For manufactured products like blinds, usually not an issue. For picture frames, sometimes not! Ask me how I know.
Just a picture that didn’t come out straight. It was big and heavy and the hangers were in the corners, but once the holes are made in the sheetrock, they are hard to correct…
