Do updates affect focusing & being online?
I have been trying to get my GF online for over an hour - just got a random support message saying there is an update -could this be affecting my ability to get online. I’ve unplugged, disconnected, etc to wifi and GF to reset - not making a difference. Tried to set-up up GF wifi again - It’s not finding my connection.
Generally not. WiFi is often due to your WiFi equipment. Check that your other devices find the WiFi signal and also that your WiFi access point is still broadcasting on 2.4 GHz.
There is a lot of information in this thread that may help, specifically the video. Try that and document the results in as much detail as you can so that Support or other owners can assist you.
That pops up anytime you’re not logged in - it’ll go away once you’ve cleared it on the machine after you’re logged in (I see it everyday as I log in via a incognito window :slight_smile: )
It looks like your Glowforge was able to connect successfully to your network, but it may be having trouble maintaining a stable connection. When this is the case, you won’t need to go through Wi-Fi setup again, but you may see an “Offline” message.
We have two more suggestions that often make a big difference:
  1. Improve the signal path between your Glowforge and your Wi-Fi access point
    Wi-Fi signals need a clear path. Remove physical barriers, and move devices closer together:
  • Move your Wi-Fi access point up high and make sure it’s in an open space. Avoid locating your Wi-Fi access point on the ground, under a desk, in a cabinet, or in a corner where its signal can be blocked.
  • Relocate your Wi-Fi access point closer to your Glowforge
  • Move your Glowforge closer to your Wi-Fi access point
  • Install a Wi-Fi range extender closer to your Glowforge
  • Run an ethernet cable and install a second Wi-Fi access point next to your Glowforge
  1. Reduce electronic and Wi-Fi interference
I hope these tips work for you. Let me know how it goes!
Thanks – but I reset everything and re-logged in and still offline
I’m sorry you are still having offline issues.
Though network-specific Wi-Fi challenges may occur for a number of different reasons, I have a few suggestions that may help:
  • If your Wi-Fi network includes several access points, it’s possible that your Glowforge needs to re-establish its connection whenever it ‘hops’ from one access point to another. As a test, you could try creating a dedicated access point for the Glowforge to see if that helps.
  • Since Glowforge only uses the 2.4GHz frequency, a connection will be harder to establish and maintain on a crowded 2.4GHz network. Other devices using 2.4GHz, like cordless phones and microwaves, can cause interference and an unstable connection. You can consult your router settings to check the performance and traffic on your 2.4GHz network.
  • In your network settings, check the channel you’re using for the 2.4GHz band. Trying a different channel may provide a more consistent connection.
  • Though less common, DNS or name resolution conflicts may also cause intermittent connectivity problems. If you use a custom DNS configuration on your router, you might want to try default DNS settings to see if that works better.
If you’re still having trouble, there’s a test you can try that will help us narrow down the problem. If possible, could you please create a Wi-Fi hotspot with a cell phone and use that network to connect your Glowforge to Wi-Fi? This is a good way to rule out signal interference since you can set your phone right on top of your Glowforge!
You can find instructions online to help you create a Wi-Fi hotspot using a cell phone. Make sure that you set it up to be a 2.4 GHz hotspot, since that is the frequency your Glowforge uses.
Once the Wi-Fi hotspot is broadcasting, you can connect to it by following these steps:
  1. Turn on your Glowforge.
  2. Wait 30 seconds. Then hold down the button for ten seconds until it glows teal.
  3. Navigate to setup.glowforge.com and follow the instructions on-screen. When prompted to connect your Glowforge to Wi-Fi, choose the hotspot you created.
  4. Once Wi-Fi setup is complete, go to app.glowforge.com and try a few prints.
Let us know how it goes.
