Hello,
I’m a totally newbie and I’m very happy to share my first design with the community. I’m pretty sure you will understand my happiness of creating something for a first time better than my friends
So my friend ask me to creat something for his dog and I ended up with this one. They look so good and now all my friends with dogs have one.
I wasn’t very sure if I did a good job but after few people ask me for a file I uploaded on Etsy and this was a hit.
I’m still learning Inkscape and believe in my self that I will create wonderful things
For this ornament I used:
Clear acrylic 1/8"
Black acrylic 1/8"
Walnut plywood 1/8"
Baltic birch plywood 1/4"
Similar in concept to what I did a couple of years ago for Valentine’s Day.
Mine is made from 5 stacked layers. 3 wood, 2 acrylic + wood. For the layers with the acrylic, the acrylic is cut slightly smaller than the outline of the heart, and a wood piece with a bigger cutout that the acrylic fits in to fits around it. So that you don’t see the acrylic layers from the outside.
Wastes a lot of wood. But looks great.
Yeah, to stick it all together, Cyanoacrylate works just fine if you sand the mating surfaces down to remove the glossy coat they’re covered with. Cyanoacrylate will not stick to the sealed surface of Proofgrade wood. And you also want to be careful with how much CA you apply, since it will fog the acrylic if you apply too much. With my setup, the acrylic isn’t actually glued, it’s captured by the wood pieces. So I didn’t need to get any glue near the plastic.
Little known fact - Cyanoacrylate was invented as an adhesive to use on plastic gunsights for US aircraft during WWII, but it was rejected because it was too sticky. Then, a decade later it was independently reinvented in a search for adhesives to glue plastic bubble canopies for jet aircraft. It was rejected for this purpose because it fogged the plastic. But they realized it glued a lot of other stuff just fine and it started getting sold as a general purpose adhesive and now we use it for everything (except acrylic).
Welcome! You have every right to be happy about this, and I would be too! That you’re new to GF and Inkscape makes it even more impressive. Thanks for sharing.
