Okay, so I’ve had my Glowforge for a little over a month now. I am finally at the level I can contribute something here. I needed stands for my dogs’ bowls, 'cuz I was tired of looking at them sitting on cardboard boxes (hubby’s idea). This is a single bowl stand for a 6.5" diameter bowl (medium-size dogs) . My dogs have a running water fountain, so I just needed singles for food.
I used .5" select pine (planed to that size). I made the legs on https://www.festi.info/boxes.py/ to get the finger joints right for .5" wood, and then edited the svg file for the cutouts. The rest of the file I made based on my bowl measurement. The stand is 5.5" high. I connected the tops to the legs with dowel joints & glue. After assembly, I sanded the edges, corners, & joints, and stained. Finally, I did a couple coats of polyurethane to protect the wood from moisture.
The svg file has the top and two legs. You have to cut two more legs.
If you want to make your design bigger than it currently is
go back into edit and find where it says “[image|15x10]” and make it 300 x 200 or something similar
That’s great! I wish I could make one for my dog but I don’t have a pass through. it needs to be 28" high. The joys of being owned by a great dane! LOL
Click on the pencil icon to edit
Click on upload and add your .svg (you’ve already done this part)
Then after it’s done uploading you’ll see it will have added a size tag (probably at 15x10)
Edit that size tag to something significantly larger
@deirdrebeth thanks for the help! I think I got it now! @designvh619 I had that problem with a box I was making and split the pieces in the svg file and joined them to make pieces larger than my Plus can handle. It’s a bit of work on the design end (especially if you are a novice designer like me ), but it can be done.
@pinky_9103 right click on the picture and save as svg file. As you are new, I’ll point out that you must use this file on .5" wood, or the finger joints won’t be right. Each kind of wood needs its own settings, so be sure to make some test cuts in whatever you plan to use.
