The frame is PG Medium Walnut, connectors are PG Medium Basswood ( you can use anything, I just liked the contrast)
When you are putting it together you have to kinda pull up on the connectors where they have the nub so it can slide down. Put a short and a long side together first, then another long side, then put the connectors on the short side (at both ends) and push down onto the rest of the frame.
If you want a solid back just print one of the inside pieces without the center cutout!
Hope you like!
File 1 is the frame, File 2 is the Acrylic
Thank you. Coming from you that is quite a compliment! Not sure a simple frame deserves that much praise. But I will always post things that can be snapped together. After being a woodworker and using glue and nails, it’s fun to create things that don’t require any.
I didn’t mean to make that sound flippant. I understand that some people have a hard time creating things. I hope by me sharing files it helps someone else not have to think so hard. I wish I was on the payroll!!!
This is so great! Thank you so much for sharing your design. I’m always in the market for a frame…and like you, especially one that doesn’t need to be glued.
