I tweaked the Glowforge ear saver design to remove the sharp / right-angle corners at either end. This makes the design little more human friendly when putting on and removing.
Here are photo of our 1st production batch using the tweaked design.
I’ll post the SVG cut file once I have a chance to remove our logo.
We are also making Face Shields for emergency medical service (EMS) professionals in New York City. If you are interested you can read more here: http://ppe.moe
The attached SVG includes cut lines for a full sheet of Made On Earth’s tweaked version of the ear saver design. The cut lines are optimized for single pass cuts / no duplication of cut lines on adjacent ear savers.
The SVG also includes hidden group (“Parts for no duplicate cuts”) that contains all the component paths of a single ear saver to help you rearrange the sheet or make new variations as needed.
Just need an SVG editor, something like Inkscape. The SVG file I shared contains separate cut paths for each ear saver, so you can simply delete or hide the ones you don’t want.
I really like your design! I am new at this and have only made the original design so far. How do I download your file? I could not find a link for the download, unless I just don’t know how to do that! I could only find a link to download the pic of the red MOE ones you made. Thanks for sharing!
in the second post there is the design in red ink in outline format… right click on that picture and choose SAVE AS … it will save it to your computer in SVG format.
one thing i would suggest is to run a simplify path on it. when i opened it up, there were 56k nodes. i ran simplify path in illustrator at a level that didn’t change the curves and it was down to closer to 4300 notes. that will load a lot faster and probably run a little smoother.
I’m using Inkscape, so I’ll have to dig into Inkscape a little more as the simplify paths option they have was too aggressive and messed things up a bit. I’m sure it possible in Inkscape as well, just haven’t had any luck with it so far.
