Since this is non-proofgrade with settings, it should be in Beyond the Manual, so i’m re-classifying for you. Great Job, though, on the project! They look awesome.
I don’t like macrons at all, but now I feel like I need to start engraving them. Totally doing this for my daughter’s next birthday! (She loves macarons).
I removed the crumb tray and put a couple cork trivets I had laying around under it, bringing it to a thickness of 1.47. That minus the 1.35 thickness of the crumb tray got me to run it at .12 focus height.
I need some help. I just recently bought my GF, May 2020. I am trying to engrave macarons. I used the settings about and removed the crumb tray. They are not coming out. The images were not lining up so I made a jig. Still not lining up. I placed the macarons on a cutting board for a total height of 1 inch with out tray, but keep getting an error message about min/max height. Any help or suggestions appreciated!
The top of the honeycomb tray is about 1.35" from the bottom of the Glowforge. The top surface of your material must be at least 1.35" from the floor or it is out of range. I suggest you read through some of the threads about using the Glowforge without the honeycomb tray and print out the no math tool. Also, don’t eat engraved food from your Glowforge unless you only use it for food.
