No-Math Focus Ruler
Leveraging the recently-released Set Focus tool, I’ve designed a tool to help place materials when the crumb tray has been removed, no maths required.
If your material is between the lines while resting on the bottom of your GF – not the crumb tray, you should be able to use Set Focus in the UI. If the top of your material is below the bottom line, use your favorite method (sheets of PG, tiles, 3-D printed stands, matching sets of trained hedgies, etc.) to elevate it and recheck. Repeat until the top is in the sweet spot between the lines.
I recommend elevating materials about halfway between the lines. It should be high enough for the focus to work correctly, but not so high as to interfere with the air-assist scoop.
Edited 10/20/2022: This file has been published in the Glowforge Catalog (linked below). It is listed as “Free with Premium,” and $1.49 (single)/$2.49 (unlimited prints) for those without the premium subscription.
Engraving Larger Depths (Removing crumb tray)
Using "set focus" with material over .5" (No tray)
MacBook Etching
The Glowforge bed image is smaller than my material
Help With Settings?!
Measuring tool
Engraving cutting boards
Height Adjustment Tool WIP
Files for Making Tools You Will Probably Need
Cutting Settings/Thickness
How to print onto An object bigger than half inch thick
Help Wanted Cutting Board
Engrave on MDF 1”
Why is it not printing where I want it?
Where Do I Begin?
Tray info
Making a cutting board
Allignment
Engraved Macarons
Live Edge Wood - Won't engrave - Material Thickness Error
Has anyone engraved a basswood country round?
Artwork size not matching Scanned material size
Engraving Bamboo Portable Charger HELP PLEASE
Issues engraving on thicker material
Print Stopped -- Won't engrave
Measuring tool: make or buy?!
Problem with print head scoop assembly hitting work
Engraving a Walmart Hard Covered Sketchbook
Allignment
Image on Screen looks Great but alignment on item in glow-forge is off!
Crumb Tray Removal
Positioning issue!
Wooden Boxes from Dollar Tree anyone figure out how to engrave?
Dire need of a Crumb Tray
Perfect alignment on a piece that is 3/4" thick
Wrong autofocus calculation
2 inch high item - help with the math!
I hope I didnt ruin my laser. Its only 3 days old!
Alignment Issue - What am I doing Wrong?
Receiving a measuring error on an item that is 1.8”
How do I engrave and score precisely without the tray?
Offline Engrave
Material thickness stopping upload
What is optimal height when engraving without the tray
Birch bark
Questions from a Newbie
Uncertified material issue
Honeycomb out to engrave
Updated grid for engraving without crumb tray
GF error regarding material thickness
Printing on Acrylic Gesso Primed Canvas?
Shorter Glowforge Tray
My laser isn't firing
Need help with a tool
Trouble with Focus Height /Material Thickness
Anyone have this issue printing? Not centered and blurry?
Determining heights to use with or without Crumb Tray - an easy to use Guide
Engraving Hobby Lobby Wooden Plaques
GlowForge material thickness shim height calculator
Coloring of wood burn
Non-PG Wood Question
Laser moves flask before engraving
When and Why to Print without Crumb Tray
Camera issue
Engraving without the crumb tray
Recipe boards on Walnut
Accurate engrave on items without crumb tray
Changing thickness
1.5” wood bourbon barrel head
Thicker Hardwood
Engraving Food
Can you make a jig on the bottom of the machine?
PLEASE HELP! "An error occurred on your Glowforge. Please refresh your browser before printing. It may also help to turn your Glowforge off and then on again."
Engraving Food
Won't print on board
Engraved image does not line up on material the same as camera view
Print Stopped - Material Thickness Error
Woodford Reserve Bottle
ROFL! I’m gonna risk it! Thanks for the file…it’s a good idea! (And the general shape matches your earlier little half inch marker, so it keeps the stylishness going as well.) :+1:
:wink:
I was just going to create something myself for this purpose. Thank You!
Terry
Great idea Dennis, Thanks! :sunglasses:
Brilliant. Thank you.
Um yeah…I’ll risk it, too. Thank you, Dennis!
Nice little helper!
Very awesome! I think it’ll pair well with the post I made in the FB group about oversized materiel and using set focus. Think I’ll post it here so I can link your tool.
Fantastic! I wish I had thought of that lol Thanks for sharing!
That’s super. I think I’ll make one and stop doing the math :slightly_smiling_face: Thanks!
Cute! :hedgehog: Did you miss this @jules?
Thanks for the file. I’ve yet to run a job with the crumb tray out; partly because I’m not strong enough to open the front, etc., but also because I felt daunted about the math. I think this is a great incentive to come up with something to do and hubby can get the crumb tray out for me!
Chuckle! Yes, I did…been dealing with IRS issues since yesterday. Haven’t been in the best of moods. Done now though.
Sorry about the IRS stuff. Never fun! Glad you’re past it now. :slightly_smiling_face:
I still have yet to try anything without the tray in…I’ve been too intimidated. But, now I know there was a reason to wait so long…for someone to design a very cool simplified tool for me to use. :slightly_smiling_face:
Great design, thanks!
Oh man, when I retired and lost the schedule C life got much better.
As long as the material is inbetween these lines does the machine automatically focus or is that a option I am looking over on my page? If you are using a non proofgrade material it asks for you to give an estimate on height…
Thanks for the tool!
Yes and no. It will autofocus either when you use the set focus tool or at the beginning of a print. The advantage of using the set focus tool first is that it will change the camera view based on the height it determined and so placement should be fairly accurate, this basically removes the need to enter a manual material height.
Is the set focus a button in the UI ? New user here… can’t find it! Thanks for the help
It’s behind the gear in settings.
