I am in the process of creating a “lapboard” for the Great Race. (www.greatrace.com) I wan tot engrave logos on the back. I have the logo from the race, but its in Full color. Can I just load the JPEG in the SVG file and print it while in color? Or do I need to change it to a Greyscale image or something else.
One way to find out. Engraving is a pretty analog process, sometimes you just have to test it out and see.
Personally I might darken the car engrave a bit more using curves, but then I like a lot of contrast, and that may not be what you’re going for. It also depends on your chosen material, etc. Cork, for example, engraves jet black with the tiniest hint of laser power. Birch, on the other hand, takes a lot of burning to get decent color.
Next stupid question. I added a map on the background. Is the only way I can keep from it engraving twice in the area of the logos, to put them all together in PS and then upload the picture?
The column of cuts, scores and engraves on the left side of the GF GUI is very useful in helping to show what the machine will be doing. Always check out each element that is depicted and confirm the machine will be doing what you want. Sometimes, there are extra cuts, scores or engraves that are shown there because of issues with the source file. Sometimes, you can simply click to IGNORE them. Other times, you need to fix the underlying file.
