My will be arriving any day now, and I have a project I have to get started on right away and must therefore order supplies before getting a chance to play with them. So I need some advice from experienced Glowforgers.
I like how the plywood is cheaper and comes in bigger pieces. But how does it engrave compared to the solid hardwoods? If you engrave through the veneer into the composite beneath is it ugly? In photos I’ve noticed sometimes lasers have trouble engraving through the grain of hardwoods which leaves the grain raised in some areas. Are there ways of avoiding it? Can that be avoided by using plywood instead? Does it engrave more consistently, or does it look fake and cheap?
All I have engraved is the maple plywood and to me or does a beautiful job.
Depending on what you are doing, it may not be a huge price difference between the PG solid & plywood. Last week I quoted out a job for 100 coasters and the price difference for materials was only ~30 cents each. That surprised me and will definitely make solid my material of choice for all coasters moving forward.
I have done light engraves on Proofgrade ply that didn’t penetrate the veneer, and didn’t display much of a raised grain. For a deeper engrave, the consistency of the MDF core gives a pleasing uniform depth, that looks really good painted.
In some cases the raised grain may be desirable. The look and satisfaction are subjective, all depends on what your vision is for the finished product.
If you’re doing variable depth engraving (3D engraving) for effect, you probably want to use the hardwood, since it scrubs up to allow the grain to show in the deeper engrave sections.
Otherwise, for standard burned engrave color, the plywoods are fine. Engraves are very consistent.
Tried a 3D engraving on a piece of Red Oak. You would have thought that I intentionally tried to create the washboard effect. The differences in density of the early and late season growing rings was night and day to the laser. I’ll bet there was a 1/16" difference between the two ring types, and independent of the intended image. That piece of oak was completely useless for 3D work. Might have been better with a cut that exposed less of the different grain but would still mess with the image.
For solid wood 3D engraves Poplar is a good consistent material with little variation due to growth rings so very similar to MDF in terms of the engrave smoothness/transitions.
The Poplar I got (HD or Woodcraft - don’t remember) was a full half inch but cuts easily with just 2 passes - more passes and it started burning/charring.
