Hello, Has anyone engraved on Acacia cutting boards. If so , would you be so kind as to share the settings.
Also is it necessary to mask the item?
Thank you
Try using the search term “engraving on acacia”. You would be surprised how many people ask that question.
Welcome to the forum
Check the post around September '18. Search is your friend. This forum has been here for many years, so most of what you are looking for can be found if you try. Also, with any new material it is always best to do your own tests to dial in the settings you like best.
