Error message for "printer head not found"
I keep getting an error message with “printer head not found”. I’ve tried cleaning it and nothing has helped! Any suggestions?
One thing you can try is with the machine turned off gently move the camera until it is under the camera in the lid. Then turn it on and it may start up correctly.
@mariajcottrell I am so sorry your Glowforge printer is saying the Printer Head is not found.
I extracted your printer logs and it looks like you have been able to print, which is great! Are you still having the same issue?
If you are, there are two key connections I’d like you to check for me.
Could you please do the following?
  1. Turn off your Glowforge.
  2. Holding only the finished black surfaces, grasp the printer head as shown. Pull gently up and back to disengage the magnets and remove the head.
  3. There is a small tab in the center of the wire ribbon. Push down fully on the tab to release it, and gently pull the wire ribbon plug from the printer head.
  4. Take a clear photo of the gold pins inside the printer head where you just unplugged the wire ribbon. It should look like this.
  5. Pick up the printer head and wire ribbon. Make sure the tab on the wire ribbon is facing up. Slide the ribbon back into the head until it clicks.
  6. As shown, lower the printer head over the metal plate so that it rests next to the two round posts. Then push it gently away from you – you’ll feel a “click” as magnets pull the printer head until it sits snugly atop the metal plate.
  7. Pull the laser arm all the way forward.
  8. Reach over the laser arm, and to the left of the inside of the unit and you’ll see this circuit board:
  9. Take a photo of the circuit board. If the cable I’ve indicated above with the red arrow appears to be loose, please reconnect it and try printing again. This cable should ‘click’ back into place.
  10. Turn your Glowforge back on.
  11. Send us the photos you took in step 4 and step 9.
Please let me know how it goes.
