An error occurred on your Glowforge. Please refresh your browser before printing. It may also
help to turn your Glowforge off and then on again.
I am trying to load up a graphic from AI. and I keep getting this message. what the hell. I followed the work flow and converted the text but I keep getting the above error. I can import other files in the SVG format from ai
If you want to zip the file and load it here someone can check it to see what’s going on with it.
There may be an issue in your file. If you want to upload it here, we can try to help figure it out.
Jinx.
You owe me a Coke!
I have sent you an email where you can send your file that you are running into trouble with so we can take a look. To avoid duplicate communication and expedite your process, I’m going to go ahead and close this topic.
