Anyone ever try cutting “Eucatile”? Product sold at Home Depot that seems to be 1/8" thick, High Density Fiberboard (HDF) with a white acrylic facing. At $12 for a 4’ x 8’ sheet, seems like a good prototyping material.
I don’t recall seeing this material mentioned before so you might not get a lot of response. (Very possible I missed discussions about it though.) It looks interesting and might give a similar effect as this stuff. I use a lot of this and it engraves really well. If you try the Eucatile, let us know how it works.
1/8" mdf is around $8 per 4 x 8 sheet if you have access to a lumber yard.
Oh man, another material to try.
This stuff?
I had previously seen it at HD and I wondered, but this post made me want it.
HDF behaves a bit differently than MDF.
I may be wrong @PrintToLaser, but I think the stuff you linked is the same whiteboard in the link I shared. This is an example of it.
I’ll have to give this a shot. The white background gives a great contrast to the burn.
Every time you play with the power you see a different level of detail
