I have been tossing around the idea of getting a filter for the forge and moving it upstairs…but was concerned about the noise it makes. Pretty high pitched when running.
I also have an inline blower for my vent system that pulls 300cfm. Since that is more than the GlowForge fan does on its own, I thought I would test out how quiet the machine was with the “air filter attached” option set. I can’t believe how loud that internal fan is.
My question is this…if I use my 300cfm inline vent fan, is it okay to leave the internal off? The few test runs I’ve done haven’t been any different smoke/smell wise in the house. Done acrylic, wood and aluminum…all the same so far.
To my brain, it seems like it should be fine. But I don’t know if the switch turns anything else on/off.
Have you had any issues with removing your internal fan? My GF was flaming a lot, so I thought my internal fan was blocked or old. I added the AC Infinity 6" and I am still having the same flaming issues. I was thinking about removing the internal fan, but now I can’t get the flames to stop, and can’t run the GF at all safely. Wondering if it is something else. Intake is clear, and air assist fan is clean. I cleaned all the lenses. There are not any system warnings, so I am just not sure what to do.
No clue. I don’t get flames. The only time I have any issue is when my air assist needs cleaning. I removed the exhaust fan because it was blocking air flow for my inline fan.
