I use custom software to generate SVG files which I currently upload to my Glowforge manually. However, it would be handy if there was an API (preferably REST) that could be used to automatically upload designs and potentially load/position/configure designs ready for cutting/engraving as well.
I could envision using the API for the following features:
- Glowforge status
- CRUD operations on “designs”. (and “folders” when they arrive)
- Operations to work with “layouts”. Where a “layout” is one or more designs (and/or artwork) loaded and positioned for cutting/engraving. Along with the settings for each. This layout could also be temporary or it might be savable for re-use later.
And I’m sure this list will expand as you folks continue to work on the GFUI.
I wasn’t able to find any docs on this sort of support with Glowforge. So I apologize if this already exists of has already been requested.
