The engraving feature works really well and understandably the default setting is that black is engraved and white is untouched.
My request is a checkbox button (or other UI method) to provide the option to invert that.
Of course, you can do this at design time but it would be nice to be able to toggle it from the GFUI.
Would be handy. Though an easy workaround is to just invert the colors (make it a negative) in an image editor.
This is a tricky one. For example if you have a 1” circle and you hit invert, should it invert the whole 20x12 area and engrave all of it but the circle?
No. There, tricky problem solved.
I don’t see much of an application for this personally. I’ve never had a time when I wanted the whole bed engraved instead of just one object.
I think the gist of this post was if someone had an object with negative space inside it to invert that with the positive space, while staying inside the bounds of the object. Determining those bounds would be difficult if not impossible in some cases
The GFUI seems to do a good job knowing what the parameters of my engrave image are. Inverting the colors purely within those bounds would be the common sense way of doing it.
There are two good use cases I can think of for this sort of feature:
That’s what I’m saying. Nobody wants to invert the whole bed, just the image to be engraved. It might not make sense to apply this to vector art, but since engraves are raster anyway, it’s probably not that hard to do the thing people want most of the time.
Problem is, as we’ve seen, if you do something that works most of the time, people are really mad when it doesn’t. On some of these things, it probably makes more sense to keep polishing what they’ve got rather than adding more surface area for people to be upset with. For now, anyway.
What if this were an option specific to picture engraves, a checkbox option along with the vary power option?
If you are talking about in a raster image, yeah that seems totally doable, and I agree with you
I also think a mirror option would be incredibly helpful
I have seen a lot of raster engraves where the engraved part of the image looks lighter than the main image (like on slate). A negative engrave would come in handy for that.
Exactly. I thought originally he was talking about vector objects.
Invert raster would definitely be helpful. I think I’ve even posted the same thread a while back
The tricky part is that often you want to remove the background when inverting otherwise you get a big box around the inverted image. (Obviously if the background was transparent to begin with it’s not an issue.) It would be difficult for the GFUI to figure out what to trim. But for images that already have a transparent background it would work great.
