File error
I am getting error when I try to cut this out. The Blue lines are cuts. The rule and the images are engraves. Any help would be nice.
Turtle Swatch
What sort of error are you getting?
It loaded in my interface without issue. I dragged it on the bed.
Turtle Swatch
it could be cleaned up better, but I rasterized your images which were the problem…
well… uploading it here stripped the images… Sigh.
That should work
it’ll give an error once you try to print. Closed path or filled error.
Thanks for all the help everyone.
I made the swatch thing in inkscape. I think I narrowed down the issue to the line in the rule.
I would recommend changing the inside line to a different color and having that cut before the outside.
There is a way to order the cuts? I have had separate cuts before and I haven’t noticed a specific order I could set.
Yes. Drag them on the left-hand side of the UI.
Reordering steps is one of several tips you might pick up here if you ever have some free time:
Yes they appear one under the other on the left of your screen and that is the order they cut. You can grab any one of those and slide them up or down to have them cut before or after another step. The more colors you use the more steps appear to the left.
